RJB57
Mar 19, 2020Follower
4.2
I have a modem/router that I had to move because of an electrical issue. When I moved it it started back up but only the 5g option showed up for selection. The problem is that Google home only works on 2.4. How can I get back to 2.4. Any suggestions would be helpful.
thanks
1 Reply
Check the user manual on how to configure the wifi radios on the modem. You should be able to setup both radios for a separate SSID name and PW which devices can connect too. The SSID names can be unique and custom. Make it intutive so you can see what they are on other devices.
