pollardd
Aug 04, 2019Aspirant
4G Signal Bars drop from 5 to 2 after 30 minutes and stays that way
Hi Guys, I have a LB2120 and it is working fairly well. I'm in a regional area and have it connected to an external 4G antenna. It's permanently connected to 4G it isn't not used in fail over mode...
Aug 05, 2019Guru - Experienced User
Please post about this in the mobile routers forum:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you.
pollardd wrote:Hi Guys,
When I first boot the device it shows 5 signal bars on the modem and it goes like a rocket.
Ping 39ms 53Mbps Down and 28Mbps Up.
After around 30 minutes it drops back to 2 signal bars and and stays that way indefinately
The speed is considerably slower especially the upload speed.
Ping 39ms 29Mbps Down and 2.85Mbps Up.
This is very consistant. It does it every time I reboot.
Does anyone know what is going on here?
pollardd
Aug 05, 2019Aspirant
Ok I'll post it again in that forum although this isn't really a Mobile Device or a HotSpot Modem.
David
- FURRYe38Aug 06, 2019Guru - Experienced User
It's a mobile phone modem/router so that will be the most appropriate forum:
https://www.netgear.com/support/product/LB2120.aspx
Good Luck.
