orchidhammer
Jul 06, 2022Aspirant
5 ghz SSID to 2.4 ghz SSID
Model: C7000v2 Firmware: V1.03.03 Wifi connection to Brennan B2 Keep losing connection to B2 due to constantly changing IP address (assigned by router?). It seems the wifi dongle for the B2...
Jul 06, 2022Guru - Experienced User
What is Brennan B2? A device?
Is Smart Connect enabled on the modem?
- orchidhammerJul 06, 2022Aspirant
Brennan B2 is a music storage/playback system. Allows you to load CDs and replay them. I can interact w/ it via wifi from Mac and iPhone. HOWEVER, IP address (provided by router?) keeps changing so URL needs to change as well to reflect new IP address.
Don't know where to check for Smart Connect.
- FURRYe38Jul 06, 2022Guru - Experienced User
Try this first, set a IP address reservation for this one device ON the modem:
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router?article=25722
Smart Connect maybe seen on the Basic/Wireless settings page on the modem.
I've gone thru the process of reserving a specific address MULTIPLE times with no success. Sometimes the IP address changes as I toggle from Advanced>Setup>LAN Setup to Basic>Attached Devices.
Is there a way to change a connection from the 5 ghz SSID to the 2.4 ghz SSID? If this doesn't work, I'm thinking my 6-year old C7000v2 is failing.
