orchidhammer
Jul 06, 2022Aspirant
5 ghz SSID to 2.4 ghz SSID
Model: C7000v2 Firmware: V1.03.03 Wifi connection to Brennan B2 Keep losing connection to B2 due to constantly changing IP address (assigned by router?). It seems the wifi dongle for the B2...
Jul 06, 2022Guru - Experienced User
So when setting the IP address reservation, when your on this screen and you have an IP address input, after you select apply. I would turn OFF the device. Then reboot the modem. After the modem is rebooted, re-confirm that the IP address reservation is still there for this device under LAN setup. If so, then turn ON the device and check the device.
What is the name given for this IP address reservation. Make sure there is no special characters or spaces in the device name.
It's up to the device to pick and choose which frequency it connects too IF Smart Connect is enabled. If Smart connect is NOT enabled, then you can have separate SSID names that you can point the device too and it should connect to the 2.4Ghz SSID only.
orchidhammer
Sequence of rebooting the B2 and router could be the problem. I'll give that a try.
Addresses are all 192.168.0.#
There is no Smart Connect option available in the Netgear Genie.
- FURRYe38Jul 06, 2022Guru - Experienced User
Using the Genie app or the modems web page? Check the modems web page for this.
I would change the IP address pool size to 192.168.0.100 to .200.
- orchidhammerJul 06, 2022Aspirant
Netgear Genie I use is https://192.168.0.1
I tried using higher numbers when reserving the address with no luck
Try setting the small IP address pool range size then setup a reservation as suggested.
