orchidhammer
Jul 06, 2022Aspirant
5 ghz SSID to 2.4 ghz SSID
Model: C7000v2 Firmware: V1.03.03 Wifi connection to Brennan B2 Keep losing connection to B2 due to constantly changing IP address (assigned by router?). It seems the wifi dongle for the B2...
orchidhammer
Sequence of rebooting the B2 and router could be the problem. I'll give that a try.
Addresses are all 192.168.0.#
There is no Smart Connect option available in the Netgear Genie.
Jul 06, 2022Guru - Experienced User
Using the Genie app or the modems web page? Check the modems web page for this.
I would change the IP address pool size to 192.168.0.100 to .200.
- orchidhammerJul 06, 2022Aspirant
Netgear Genie I use is https://192.168.0.1
I tried using higher numbers when reserving the address with no luck
- FURRYe38Jul 06, 2022Guru - Experienced User
Try setting the small IP address pool range size then setup a reservation as suggested.
I'm a little leery to change the range as several other devices are connected using smaller number ...0.11, ...0.23, ...0.18, etc.
They will get new IPs when the modem reboots.
W/ B2 off, I reserved an IP address within specified range in Netgear Genie via Advanced>Setup>LAN Setup and hit Apply.
I rebooted the router.
Turned B2 on.
AND THE IP ADDRESSES CHANGED
Attached Devices: 192.168.0.14 (don't know where this came from)
Advanced: 192.168.0.57 (this is the address I reserved)
B2 Display: 192.168.0.20 (number assigned by router)
Is it possible to completely delete any mention of my peripheral from the Netgear Genie.
I'd like to reconnect from scratch and see what happens.
SHAZAM!!!!
I think I got it. I blocked the original B2 in the Attached Devices List. Reserved the address assigned by the router, and attached the B2 to a "Hidden Network" manually entering the 2.4Ghz SSID. I rebooted everything and the IP addresses remained the same.
Furry, I really appreciate the help!
I'd still like to know if I can delete the blocked items in the Attached Device list.
Glad you got it working.
IF there connected to the modem and get a IP address thru the modem I presume they will always appear there until they are no longer connected.
- orchidhammerJul 07, 2022Aspirant
How do I disconnect them and or delete them? I've blocked several that have been replaced/thrown out but they still show up.
