orchidhammer
Jul 06, 2022Aspirant
5 ghz SSID to 2.4 ghz SSID
Model: C7000v2 Firmware: V1.03.03 Wifi connection to Brennan B2 Keep losing connection to B2 due to constantly changing IP address (assigned by router?). It seems the wifi dongle for the B2...
orchidhammer
SHAZAM!!!!
I think I got it. I blocked the original B2 in the Attached Devices List. Reserved the address assigned by the router, and attached the B2 to a "Hidden Network" manually entering the 2.4Ghz SSID. I rebooted everything and the IP addresses remained the same.
Furry, I really appreciate the help!
I'd still like to know if I can delete the blocked items in the Attached Device list.
Jul 06, 2022Guru - Experienced User
Glad you got it working.
IF there connected to the modem and get a IP address thru the modem I presume they will always appear there until they are no longer connected.
- orchidhammerJul 07, 2022Aspirant
How do I disconnect them and or delete them? I've blocked several that have been replaced/thrown out but they still show up.
