Stan415
Dec 31, 2019Aspirant
5 Ghz wifi network drops/disappears frequently
Got a new Nighthawk X4 C7500 a few weeks ago to use with my Comcast Xfinity service. For about the first week, it worked great- no issues. For the last 2 weeks or so, several times a day either the 2...
Stan415
Jan 10, 2020Aspirant
Any advice at all...
darlingt1
Mar 15, 2020Aspirant
Any recommendations? I can't push or go back on updates since Xfinity controls the firmware.
- darlingt1Mar 15, 2020Aspirant
Also this is getting worse. Drop 2.4GHZ oftern and then 5 GHZ I have tired everything listed on line from Reset fac default to start over, still has same firmware. when can we get new firmware update????
- FURRYe38Mar 16, 2020Guru - Experienced User
Any Wifi Neighbors near by? If so, how many?Set 20/40Mhz Coexistence to 40Mhz only.
