sancarod
Apr 02, 2023Aspirant
5G connection unestable while 2.4 works
My 2.4 connection works but when I tried to connect to 5G it does not. Never had this issue before. I already tried to disconnect the router but it did not work. I also verified the status of the con...
sancarod
I was using Auto for 2.4 and another channel other than 48 for 5g. I changed the channel to 48 for 5g and it seems to be working.
If I experience the issue again, I will try the other suggestions you shared.
Thanks!
Apr 02, 2023Guru - Experienced User
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
