Brian1955
Dec 09, 2021Follower
5G Droping signal intermittently with CAX30
I had problems with the router dropping the 5G signal and difficulty logging in and constantly. Numerous factory resets and trying changing settings didn't fix problems. Spent a great deal of time w...
Dec 10, 2021Guru - Experienced User
Thanks for letting us know.
Enjoy.
Brian1955 wrote:
I had problems with the router dropping the 5G signal and difficulty logging in and constantly. Numerous factory resets and trying changing settings didn't fix problems. Spent a great deal of time with with tech support without resolution. Well I got some more shop light from Costco to add to some older ones I had in my garage. Included with the light was a note that the lights could interfere with some wi fi signals in the range that use 5.8ghz. I had to change to router channel to channel 40 and there is no more 5g issues. It interferes with the channels from 149-165. Hopes this helps some one.
