Acm1982
Sep 17, 2019Aspirant
5Ghz is not in range R6900
Hello. I’ve had my Nighthawk AC1900 R6900 router for a little over a year. It had no issues connecting to the 5 ghz WiFi previously and has just started showing not in range when looking for it on dev...
antinode
Sep 17, 2019Guru
> [...] connecting to the 5 ghz WiFi previously and has just started
> showing not in range [...]
Does your saying "5 ghz" mean that the 2.4GHz band works, or that
you've tried only the 5GHz band, or what?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for the LED
descriptions and "Troubleshoot". Pay special attention to "WiFi On/Off
button with LED". (Did you press it?)
- Acm1982Sep 17, 2019AspirantThe 2.4 ghz works but I’ve been able to connect to just the 5 in the past on my firestick.
