JD187's avatar
JD187
Follower
Jul 25, 2020
5ghz not working C6300v2 model.
I purchased this routers about 3 months ago. Recently I started having issues with the 5ghz WiFi not working. I cannot get a steady connection. I get an erratic, and jumpy speed on it. I have internet because I can connect to the router with a cable, and the 2.4ghz works fine. I’ve already rebooted the device 3-4 times. I have also done a factory reset on the device. I’m stuck, some help will be greatly appreciated.
1 Reply
  • FURRYe38's avatar
    What channels are you using on 5Ghz? Auto? Try setting manual channel on 5Ghz.
