mravatarish
May 25, 2016Follower
5ghz wont connect to internet
we bought this router today from walmart, got it connected to the internet, and everything. The problem occurs when you try to connect to the 5ghz chanel, it wil rest the whole router. the 2.4ghz wor...
michaelkenward
May 26, 2016Guru - Experienced User
mravatarish wrote:The problem occurs when you try to connect to the 5ghz chanel
What does this mean? What are you connecting?
mravatarish wrote:it wil rest the whole router.
I guess you mean "reset", but what does that mean?
