Matthew617
Jul 11, 2022Aspirant
8-stream AX WiFi Gateway (CAX80)
I have 1 gig service from Spectrum and the ethernet connections tops out at 450-600 while my 5g wireless is 1100. Spectrum came and checked the line and all was good. I can't see any obvious se...
- Jul 13, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jul 11, 2022Guru - Experienced User
What ethernet device are you speed testing with?
What CAT# cable are you using? CAT6 is recommended.
Is ethernet device connected to the Multi Gig port or a 1Gb port?
Is Armor, or traffic meter enabled?
Matthew617
HP Laptop
Cat8
I've tried all the ports, port aggregation is not enabled.
Armor Not Active
Traffic Meter
Cancel Apply | ||||
| Firmware Version | V2.1.3.7 |
| Cable Firmware Version | V1.02.08 |
- FURRYe38Jul 11, 2022Guru - Experienced User
So I Traffic meter enabled, hard to tell.
Try a different ethernet device?
Has a factory reset and setup from scratch with out Armor or Traffic Meter being enabled and see?
- Matthew617Jul 13, 2022Aspirant
The factory reset worked- It's up to 850...thanks!!!
- FURRYe38Jul 13, 2022Guru - Experienced User
Enjoy. 📡
