Matthew617
Jul 11, 2022Aspirant
8-stream AX WiFi Gateway (CAX80)
I have 1 gig service from Spectrum and the ethernet connections tops out at 450-600 while my 5g wireless is 1100. Spectrum came and checked the line and all was good. I can't see any obvious se...
- Jul 13, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Matthew617
Jul 13, 2022Aspirant
The factory reset worked- It's up to 850...thanks!!!
Jul 13, 2022Guru - Experienced User
Enjoy. 📡
- Matthew617Jul 15, 2022Aspirant
Resolved! Thanks!
