shrijbala
Dec 08, 2022Aspirant
8-stream AX WiFi Gateway (CAX80)
Hello, I have 2 questions : 1) I have high speed 1Gbps internet connection and at time i see the issue with Upstream level. Xfinity is my provider and they confirmed that everything is good at ...
Dec 09, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
EAX80 would be a good match for a extender.
shrijbala
Dec 09, 2022Aspirant
Hi,
ISP has verified and we have removed all the splitters that were left over in the past. I'm not sure if the insulation across the walls is hampering the signal. House is about 2000 sqft.
| Time | Priority | Description |
| Thu Dec 8 08:42:39 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Dec 8 08:42:42 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Dec 8 08:42:48 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Dec 8 08:43:39 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Dec 8 08:43:39 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Dec 8 08:43:59 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Dec 8 08:44:00 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Dec 8 08:44:18 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Dec 8 08:44:19 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Dec 8 08:44:38 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Dec 8 08:44:39 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Dec 8 08:44:59 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Dec 8 08:45:04 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Thu Dec 8 09:09:05 2022 | Notice (6) | TLV-11 - unrecognized OID;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Dec 8 09:09:23 2022 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Dec 8 11:06:52 2022 | Notice (6) | CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Dec 8 11:07:21 2022 | Notice (6) | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Wed Dec 7 22:42:27 2022 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
| Wed Oct 26 00:07:07 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Wed Oct 26 00:07:08 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Wed Oct 26 00:07:27 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Wed Oct 26 00:07:28 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Wed Oct 26 00:07:47 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Wed Oct 26 00:07:52 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Thu Jan 1 00:00:44 1970 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Thu Jan 1 00:00:49 1970 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Jan 1 00:00:55 1970 | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
| Thu Jan 1 00:02:07 1970 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Jan 1 00:03:52 1970 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Jan 1 00:05:15 1970 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
| Thu Jan 1 00:06:38 1970 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1; |
- shrijbalaDec 09, 2022Aspirant
To add, CAX80 is my modem + router and I do not have a separate Modem from the ISP. My home is 2000+ sqft but has 3 floors.
Does 1 EAX80 sufficient for this?
Thanks,
Bala
- FURRYe38Dec 09, 2022Guru - Experienced User
You can lots of criticals that the ISP needs to review and resolve.
Please post a copy and paste of the modems connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-routerFor that size of home the CAX80 would be enough. If you add a EAX80, I would turn down the power on the CAX80 radios from 100% to 50%.
Here it is.
Cable Diagnostic
Status: Poor
Action:
[Upstream Power Level]
Try these actions (Click the Refresh button after each step):
1) Make sure the coaxial cable is tightly connected.
2) Remove any unnecessary splitters.
3) Replace any required splitters.
4) Contact your service provider for troubleshooting help.Internet Access: Good
Downstream Status: Good
Downstream Power Level: Good
Downstream SNR: Good
Upstream Status: Poor
Upstream Power Level: Poor
Upstream power is poor (29.3dBmV). The recommended level is from 30 to 55dBmV.
Current time: Fri Dec 09 12:15:51 2022Startup Procedure
Acquire Downstream Channel: 579 MHz Locked
Connectivity State: OK Operational
Boot State: OK Operational
Security: Enabled BPI+
Downstream Bonded Channels
Channel LockedStatus Modulation ChannelID Frequency Power SNR Correctables Uncorrectables
1 Locked 256 QAM 25 579000000 Hz 2.6 dBmV 39.9 dB 0 0
2 Locked 256 QAM 13 501000000 Hz 3.1 dBmV 40 dB 0 0
3 Locked 256 QAM 14 507000000 Hz 2.8 dBmV 39.9 dB 0 0
4 Locked 256 QAM 15 513000000 Hz 2.8 dBmV 39.9 dB 0 0
5 Locked 256 QAM 16 519000000 Hz 2.9 dBmV 39.9 dB 0 0
6 Locked 256 QAM 17 525000000 Hz 2.9 dBmV 39.9 dB 0 0
7 Locked 256 QAM 18 531000000 Hz 3 dBmV 39.9 dB 0 0
8 Locked 256 QAM 19 537000000 Hz 3 dBmV 39.9 dB 0 0
9 Locked 256 QAM 20 543000000 Hz 2.8 dBmV 39.9 dB 0 0
10 Locked 256 QAM 21 549000000 Hz 2.7 dBmV 39.7 dB 0 0
11 Locked 256 QAM 22 555000000 Hz 2.7 dBmV 39.8 dB 0 0
12 Locked 256 QAM 23 567000000 Hz 2.7 dBmV 40 dB 0 0
13 Locked 256 QAM 24 573000000 Hz 2.7 dBmV 40 dB 0 0
14 Locked 256 QAM 26 585000000 Hz 2.4 dBmV 39.9 dB 0 0
15 Locked 256 QAM 27 591000000 Hz 2.6 dBmV 40 dB 0 0
16 Locked 256 QAM 28 597000000 Hz 2.4 dBmV 40 dB 0 0
17 Locked 256 QAM 29 603000000 Hz 2.3 dBmV 40 dB 0 0
18 Locked 256 QAM 30 609000000 Hz 2.1 dBmV 40 dB 0 0
19 Locked 256 QAM 31 615000000 Hz 1.8 dBmV 39.9 dB 0 0
20 Locked 256 QAM 32 621000000 Hz 1.4 dBmV 39.8 dB 0 0
21 Locked 256 QAM 33 627000000 Hz 1.8 dBmV 39.9 dB 0 0
22 Locked 256 QAM 34 633000000 Hz 1.9 dBmV 39.9 dB 0 0
23 Locked 256 QAM 35 639000000 Hz 1.9 dBmV 40.1 dB 0 0
24 Locked 256 QAM 36 645000000 Hz 1.8 dBmV 40.1 dB 0 0
25 Locked 256 QAM 37 651000000 Hz 2 dBmV 40.1 dB 0 0
26 Locked 256 QAM 38 657000000 Hz 1.9 dBmV 40.1 dB 0 0
27 Locked 256 QAM 39 663000000 Hz 1.9 dBmV 40.1 dB 0 0
28 Locked 256 QAM 40 669000000 Hz 1.7 dBmV 40.1 dB 0 0
29 Locked 256 QAM 41 675000000 Hz 1.7 dBmV 39.5 dB 0 0
30 Locked 256 QAM 42 681000000 Hz 1.6 dBmV 40.2 dB 0 0
31 Locked 256 QAM 43 687000000 Hz 1.7 dBmV 40.1 dB 1 0
32 Locked 256 QAM 44 693000000 Hz 1.7 dBmV 40.1 dB 1 0
Upstream Bonded Channels
Channel LockedStatus ChannelType ChannelID SymbolRate Frequency Power
1 Locked ATDMA 10 5120 Ksym/sec 16400000 Hz 29.3 dBmV
2 Locked ATDMA 11 5120 Ksym/sec 22800000 Hz 29.8 dBmV
3 Locked ATDMA 12 5120 Ksym/sec 29200000 Hz 30.8 dBmV
4 Locked ATDMA 13 5120 Ksym/sec 35600000 Hz 30.8 dBmV
5 Locked ATDMA 14 2560 Ksym/sec 40400000 Hz 33.8 dBmV
6 Not Locked Unknown 0 0 0 0.0
7 Not Locked Unknown 0 0 0 0.0
8 Not Locked Unknown 0 0 0 0.0
Downstream OFDM Channels
Channel LockedStatus ProfileID ChannelID Frequency Power SNR/MER ActiveSubcarrier Unerror Correctable Uncorrectable
1 Locked 0 ,1 ,2 ,3 159 702000000 Hz 2.68 dBmV 39.9 dB 1126 ~ 2969 3333917890 567946455 0
2 Not Locked 0 0 0 Hz 0 dBmV 0 dB 0 ~ 4095 0 0 0
Upstream OFDMA Channels
1 Not Locked 0 0 0 Hz 0 dBmV
2 Not Locked 0 0 0 Hz 0 dBmVEvent Log
Time Priority Description
Thu Dec 8 11:07:21 2022 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 11:06:52 2022 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 09:09:23 2022 Notice DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 09:09:05 2022 Notice TLV-11 - unrecognized OID;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:55 1970 Notice Honoring MDD; IP provisioning mode = IPv6
Thu Dec 8 08:45:04 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:44:59 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:44:39 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:44:38 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:44:19 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:44:18 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:44:00 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:43:59 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:43:39 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:43:39 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:42:48 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:42:42 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:42:39 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:44 1970 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Wed Dec 7 22:42:27 2022 Critical Resetting the cable modem due to docsDevResetNow
Thu Jan 1 00:06:38 1970 Critical No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:05:15 1970 Critical No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:03:52 1970 Critical No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:02:07 1970 Critical No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:49 1970 Critical No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:07:52 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:07:47 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:07:28 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:07:27 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:07:08 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:07:07 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:06:49 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:06:48 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:06:28 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:06:27 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:05:41 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:05:35 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:05:32 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:05:10 1970 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
