shrijbala
Dec 09, 2022Aspirant
8-stream AX WiFi Gateway (CAX80)
Hello, I have 2 questions : 1) I have high speed 1Gbps internet connection and at time i see the issue with Upstream level. Xfinity is my provider and they confirmed that everything is good at ...
Dec 09, 2022Guru - Experienced User
You can lots of criticals that the ISP needs to review and resolve.
Please post a copy and paste of the modems connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
For that size of home the CAX80 would be enough. If you add a EAX80, I would turn down the power on the CAX80 radios from 100% to 50%.
shrijbala
Here it is.
Cable Diagnostic
Status: Poor
Action:
[Upstream Power Level]
Try these actions (Click the Refresh button after each step):
1) Make sure the coaxial cable is tightly connected.
2) Remove any unnecessary splitters.
3) Replace any required splitters.
4) Contact your service provider for troubleshooting help.
Internet Access: Good
Downstream Status: Good
Downstream Power Level: Good
Downstream SNR: Good
Upstream Status: Poor
Upstream Power Level: Poor
Upstream power is poor (29.3dBmV). The recommended level is from 30 to 55dBmV.
Current time: Fri Dec 09 12:15:51 2022
Startup Procedure
Acquire Downstream Channel: 579 MHz Locked
Connectivity State: OK Operational
Boot State: OK Operational
Security: Enabled BPI+
Downstream Bonded Channels
Channel LockedStatus Modulation ChannelID Frequency Power SNR Correctables Uncorrectables
1 Locked 256 QAM 25 579000000 Hz 2.6 dBmV 39.9 dB 0 0
2 Locked 256 QAM 13 501000000 Hz 3.1 dBmV 40 dB 0 0
3 Locked 256 QAM 14 507000000 Hz 2.8 dBmV 39.9 dB 0 0
4 Locked 256 QAM 15 513000000 Hz 2.8 dBmV 39.9 dB 0 0
5 Locked 256 QAM 16 519000000 Hz 2.9 dBmV 39.9 dB 0 0
6 Locked 256 QAM 17 525000000 Hz 2.9 dBmV 39.9 dB 0 0
7 Locked 256 QAM 18 531000000 Hz 3 dBmV 39.9 dB 0 0
8 Locked 256 QAM 19 537000000 Hz 3 dBmV 39.9 dB 0 0
9 Locked 256 QAM 20 543000000 Hz 2.8 dBmV 39.9 dB 0 0
10 Locked 256 QAM 21 549000000 Hz 2.7 dBmV 39.7 dB 0 0
11 Locked 256 QAM 22 555000000 Hz 2.7 dBmV 39.8 dB 0 0
12 Locked 256 QAM 23 567000000 Hz 2.7 dBmV 40 dB 0 0
13 Locked 256 QAM 24 573000000 Hz 2.7 dBmV 40 dB 0 0
14 Locked 256 QAM 26 585000000 Hz 2.4 dBmV 39.9 dB 0 0
15 Locked 256 QAM 27 591000000 Hz 2.6 dBmV 40 dB 0 0
16 Locked 256 QAM 28 597000000 Hz 2.4 dBmV 40 dB 0 0
17 Locked 256 QAM 29 603000000 Hz 2.3 dBmV 40 dB 0 0
18 Locked 256 QAM 30 609000000 Hz 2.1 dBmV 40 dB 0 0
19 Locked 256 QAM 31 615000000 Hz 1.8 dBmV 39.9 dB 0 0
20 Locked 256 QAM 32 621000000 Hz 1.4 dBmV 39.8 dB 0 0
21 Locked 256 QAM 33 627000000 Hz 1.8 dBmV 39.9 dB 0 0
22 Locked 256 QAM 34 633000000 Hz 1.9 dBmV 39.9 dB 0 0
23 Locked 256 QAM 35 639000000 Hz 1.9 dBmV 40.1 dB 0 0
24 Locked 256 QAM 36 645000000 Hz 1.8 dBmV 40.1 dB 0 0
25 Locked 256 QAM 37 651000000 Hz 2 dBmV 40.1 dB 0 0
26 Locked 256 QAM 38 657000000 Hz 1.9 dBmV 40.1 dB 0 0
27 Locked 256 QAM 39 663000000 Hz 1.9 dBmV 40.1 dB 0 0
28 Locked 256 QAM 40 669000000 Hz 1.7 dBmV 40.1 dB 0 0
29 Locked 256 QAM 41 675000000 Hz 1.7 dBmV 39.5 dB 0 0
30 Locked 256 QAM 42 681000000 Hz 1.6 dBmV 40.2 dB 0 0
31 Locked 256 QAM 43 687000000 Hz 1.7 dBmV 40.1 dB 1 0
32 Locked 256 QAM 44 693000000 Hz 1.7 dBmV 40.1 dB 1 0
Upstream Bonded Channels
Channel LockedStatus ChannelType ChannelID SymbolRate Frequency Power
1 Locked ATDMA 10 5120 Ksym/sec 16400000 Hz 29.3 dBmV
2 Locked ATDMA 11 5120 Ksym/sec 22800000 Hz 29.8 dBmV
3 Locked ATDMA 12 5120 Ksym/sec 29200000 Hz 30.8 dBmV
4 Locked ATDMA 13 5120 Ksym/sec 35600000 Hz 30.8 dBmV
5 Locked ATDMA 14 2560 Ksym/sec 40400000 Hz 33.8 dBmV
6 Not Locked Unknown 0 0 0 0.0
7 Not Locked Unknown 0 0 0 0.0
8 Not Locked Unknown 0 0 0 0.0
Downstream OFDM Channels
Channel LockedStatus ProfileID ChannelID Frequency Power SNR/MER ActiveSubcarrier Unerror Correctable Uncorrectable
1 Locked 0 ,1 ,2 ,3 159 702000000 Hz 2.68 dBmV 39.9 dB 1126 ~ 2969 3333917890 567946455 0
2 Not Locked 0 0 0 Hz 0 dBmV 0 dB 0 ~ 4095 0 0 0
Upstream OFDMA Channels
1 Not Locked 0 0 0 Hz 0 dBmV
Event Log
Time Priority Description
Thu Dec 8 11:07:21 2022 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 11:06:52 2022 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 09:09:23 2022 Notice DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 09:09:05 2022 Notice TLV-11 - unrecognized OID;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:55 1970 Notice Honoring MDD; IP provisioning mode = IPv6
Thu Dec 8 08:45:04 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:44:59 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:44:39 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:44:38 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:44:19 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:44:18 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:44:00 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:43:59 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:43:39 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:43:39 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:42:48 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:42:42 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Dec 8 08:42:39 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:44 1970 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Wed Dec 7 22:42:27 2022 Critical Resetting the cable modem due to docsDevResetNow
Thu Jan 1 00:06:38 1970 Critical No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:05:15 1970 Critical No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:03:52 1970 Critical No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:02:07 1970 Critical No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:49 1970 Critical No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:07:52 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:07:47 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:07:28 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:07:27 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:07:08 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:07:07 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:06:49 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:06:48 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:06:28 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:06:27 2022 Critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:05:41 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:05:35 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Wed Oct 26 00:05:32 2022 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=04:2a:e2:c6:ba:b4;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:05:10 1970 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:40:02:78;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
