shrijbala
Dec 08, 2022Aspirant
8-stream AX WiFi Gateway (CAX80)
Hello, I have 2 questions : 1) I have high speed 1Gbps internet connection and at time i see the issue with Upstream level. Xfinity is my provider and they confirmed that everything is good at ...
Dec 09, 2022Guru - Experienced User
Power levels look good though the higher channels are lower than the lower channels seen with higher power. Still with in spec.
I'd have the ISP check the event logs to be sure things are ok here.
Review the suggestions in my first post as well if any of that could be needed.
Otherwise, you should be ok.
