adossant
Aug 08, 2023Tutor
+9dB downstream not good enough?
Connection troubleshooting states "Good Downstream power levels are within -7 to +7 dBmV". However, even at +9dB, my CM1150V was not providing a solid link, my router was frequently loosing connectiv...
Aug 08, 2023Guru - Experienced User
+9dB is too high:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
- adossantAug 09, 2023Tutor
Thank you for your response. Yes, I did see that. However, if +9dB is too high, then why does +13dB work flawlessly? Since removing the 3-way splitter increased the power to +13dB, it has worked flawlessly. I haven't had a single disconnection. I have to get ready for work, but I am attaching a snapshot of my connection status while I was experiencing the difficulties. I'll see about getting the log tonight. Thanks again.
- plemansAug 09, 2023Guru - Experienced User
If it works fine without the 3 way connector, I'd really be suspicious of the 3 way connector.
You can run your signal hot but it can cause issues and longevity problems.
that's why we recommend it at lower levels.
I see. (Although that same 3-way splitter worked fine with the Xfinity modem). Ok, is there a specific 3-way splitter that is designed to function with the CM1150V? (i.e. can you recommend one that should work with it)? Thank you for your assistance!
