adossant
Aug 08, 2023Tutor
+9dB downstream not good enough?
Connection troubleshooting states "Good Downstream power levels are within -7 to +7 dBmV". However, even at +9dB, my CM1150V was not providing a solid link, my router was frequently loosing connectiv...
Aug 08, 2023Guru - Experienced User
+9dB is too high:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
adossant
Aug 09, 2023Tutor
Thank you for your response. Yes, I did see that. However, if +9dB is too high, then why does +13dB work flawlessly? Since removing the 3-way splitter increased the power to +13dB, it has worked flawlessly. I haven't had a single disconnection. I have to get ready for work, but I am attaching a snapshot of my connection status while I was experiencing the difficulties. I'll see about getting the log tonight. Thanks again.
- plemansAug 09, 2023Guru - Experienced User
If it works fine without the 3 way connector, I'd really be suspicious of the 3 way connector.
You can run your signal hot but it can cause issues and longevity problems.
that's why we recommend it at lower levels.
- adossantAug 09, 2023Tutor
I see. (Although that same 3-way splitter worked fine with the Xfinity modem). Ok, is there a specific 3-way splitter that is designed to function with the CM1150V? (i.e. can you recommend one that should work with it)? Thank you for your assistance!
Most decent quality ones should be fine. Its not always the splitter. It could be the end connector that it doesn't have caps on it, not being tight enough, etc.
I used to run around that same 13-14dbmv and it worked fine. Then I started to get errors so I used to just use a 4x way splitter for a while but then it started having errors. so I just picked up a signal attenuator and connected that in line. Has been working fine for around 6-8 months. They're not to expensive. I think I picked up a 3,6,9 dbmv attenuator so I could play around with the signal levels.
