Tommiee
Dec 11, 2022Aspirant
AC-1200-C6230
Hi. I have an AC-1200-C6230. I noticed the 2.4GHz and 5 GHz lights were not on. I unplugged it as I have to do once in awhile when my Xfinity service messes up to fix the problem of being able to get...
Dec 11, 2022Guru - Experienced User
Not sure why/how it might have happened. We see it all the time where the wifi on/off button on the router gets hit and it causes issue but its not usually in the settings.
Eitherway I'm glad you got it working again
- TommieeDec 13, 2022Aspirant
Hi. Happy Holidays. So yeah, I probably pushed and possibly held the wifi on/off button when lifting it to dust under. Though I don't know for sure if doing so unticks the 2.4GHz & 5 GHz settings in the wireless settings. I guess the only way to know is to do it on purpose and then check my settings. But your explanation makes total sense. Thanks, Tommiee
