JW85
Jun 23, 2020Aspirant
AC 1750 C6300 keeps dropping internet
Hello, our AC1750 C6300 keeps randomly dropping the internet. It's done this for about a week now. Firmware is up to date all the connections are strong. Troubleshooting ranges but the most frequent i...
Jun 23, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
- JW85Jun 23, 2020AspirantThanks for the tips, I'll definitely look into replacing the coaxs. I believe both the neighbors have a wifi setup. I can't avoid splitters unfortunately, could replace them though as they are fairly old.
