EHP61
Feb 14, 2025Aspirant
AC 1750 WIFI not broadcasting
My router just quit broadcasting WiFi, I have reset and restarted multiple times with no luck. Power, upstream, down stream and internet lights all green. No other lights are on. Pushing and holding...
Feb 14, 2025Guru - Experienced User
Try pressing the reset button in back for 15 seconds then release then setup from scratch with a wired PC and web browser?
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
EHP61
Feb 15, 2025Aspirant
The main problem is connecting my laptop to the router. My laptop does not have a network port. USB only.
- michaelkenwardFeb 15, 2025Guru - Experienced User
You can buy a USB device that creates a wired LAN port.
As seen on Amazon, its costs around $£€10. There are many more like it.
Always worth having around.
Disclaimer: Just another user with time on their hands.
- EHP61Feb 17, 2025Aspirant
Thanks, I'll try that
