EHP61
Feb 14, 2025Aspirant
AC 1750 WIFI not broadcasting
My router just quit broadcasting WiFi, I have reset and restarted multiple times with no luck. Power, upstream, down stream and internet lights all green. No other lights are on. Pushing and holding...
EHP61
Feb 15, 2025Aspirant
The main problem is connecting my laptop to the router. My laptop does not have a network port. USB only.
michaelkenward
Feb 15, 2025Guru - Experienced User
You can buy a USB device that creates a wired LAN port.
As seen on Amazon, its costs around $£€10. There are many more like it.
Always worth having around.
Disclaimer: Just another user with time on their hands.
- EHP61Feb 17, 2025Aspirant
Thanks, I'll try that
