Often_Confused
Oct 16, 2024Aspirant
AC1200 & VOIP
Have a friend with Cox and an AC1200-C6220 cable modem that I'd suggested. We've been unable to get it to work with Callcentric & a Grandstream HT801 ATA or a Poly SIP phone. The symptoms were q...
Often_Confused
Nov 01, 2024Aspirant
We have tested the Grandstreams off-site, fed by fiber providers; no problem.
It's difficult to troubleshoot remotely, even with access to the C6220 as things change for unknown reasons; after a power failure and reboot, it changed for the worse. A Poly SIP phone is now incapacitated as well, signaling but no audio.
We'll have someone on-site in a few days. But the better overall solution looks like getting the customer to abandon DOCSIS and move to fiber; it's available, dependable, and no more expensive.
Nov 01, 2024Guru - Experienced User
Ok, thanks for the feedback.
Hope you can get it working.
Good Luck.
