lveddie
Aug 06, 2018Follower
ac1200 c6220 running hot
If this has already been posted, I apologize. Just hooked up my C6220 last week and works great. I have noticed that the coax connector at the modem seems unusually hot. Top of modem also hot. Is ...
- Aug 07, 2018
Make sure the modem is in a open place with airflow but if it gets way to hot to the touch I would contact support.
DarrenM
DarrenM
Aug 07, 2018Sr. NETGEAR Moderator
DarrenM
BPDean
Sep 03, 2018Aspirant
I have a new (end of June, 2018) Netgear modem router that is running very hot. It is in an open space with air circulating around it. Is this normal?
- DarrenMSep 06, 2018Sr. NETGEAR Moderator
If you feel it is to hot I suggest contacting support they will be able to replace the unit if needed.
https://www.netgear.com/support/contact.aspx
DarrenM
