owlette2's avatar
owlette2
ac1200 how do i stop others from using my router
the fa mily downstairs are using my service,how can i block them?
  • FURRYe38's avatar
    Which model NG router do you have? AC1200 isn't a model#.
    • plemans's avatar
      AC1200 and AC1220 aren't models.
      But your simplest route to keep others from using your router would be to change your wifi password and not to give them access to plugging a device into it.
      go to netgear.com/support/   and type in your actual model. Then you'll have access to the manual that walks you through changing passwords.
    • FURRYe38's avatar
      Well is it a R#### or C#### or something like this? This would be a model number we are looking for.
      owlette2 wrote:
      AC1220
