LogWatcher's avatar
LogWatcher
AC1200 (model C6220) Does this device log IP address conflicts?
I'm helping a friend troubleshoot a problem with his AC1200 (model C6220) cable modem.  I suspect there is a periodic IP address conflict but it's difficult to talk a non-techie person trough troubleshooting over the phone.  I thought that since that cable modem does log some events, it might log a detected IP address conflict.  Anybody know if this is the case?  If that device does indeed log such events then I will try to talk the user through logging in to the modem's web interface and checking the logs.  If not, I won't bother trying to talk the used through this.
  • > [...] I suspect there is a periodic IP address conflict [...]
       Any evidence for that?  ("periodic" or "occasional"?)
    > [...] it might log a detected IP address conflict. [...]
       I'd expect to find evidence in the log of the DHCP server granting an
    address to a client device.  I wouldn't bet that the router would notice
    a conflict, let alone record it in its log.
       In my experience, the usual cause of an address conflict is the
    presence of multiple DHCP servers on the LAN.  Less frequently, a user
    will assign a static address (not a reserved dynamic address) to some
    device, but leave that address in the DHCP pool, so that the DHCP server
    can grant it to some other device.
    • LogWatcher's avatar
      LogWatcher
      Actually, the cable morem/router is the DHCP server.  I found no information about what types of events the device logs.  Maybe I'll have to open a ticket with Netfear support.
