akpreucil
Jul 09, 2021Tutor
AC1200 WiFi Cable Modem Router(C6220) WiFi Files missing
Device: AC1200 WiFi Cable Modem Router Model: C6220 Firmware: 1.02.11 I bought this device on August 29, 2020 from Best Buy. The device was working fine until two nights ago. The WiFi suddenly ...
Itmaster1
Jul 15, 2021Aspirant
I am having the same issue from last 3 days. Did you found any solution?
- akpreucilJul 19, 2021Tutor
Hi Itmaster1,
Unfortunately I did not. I switched from NETGEAR to Motorola (which has free tech support). At least the amount I paid for the NETGEAR Modem did pay itself off rather than renting a Gateway from Xfinity. Most likely will not be buying another NETGEAR product though...
