J_O_24
May 16, 2020Aspirant
AC1600 - connectivity lags on main PC
en my wife & I started working from home full-time a few months ago, we upgraded from our previous Netgear modem router to the AC1600. (Comcast had also boosted our speed recently so the old model wa...
May 16, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
J_O_24
May 24, 2020Aspirant
FURRYe38 wrote:Have the ISP check the signal and line quality UP to the modem.
Thanks for the reply - I've been slacking and haven't checked these options yet to solve the issue but I will...
