marissat24
Oct 26, 2020Follower
AC1600 C6250 will only connect to certain devices after outage. Please help!
Hi all. My neighborhood had an outage on Friday and since then my wifi has only worked on certain devices. I never had any issues before this outage. It only connects on my Roku, but it is very in and...
Oct 27, 2020Guru - Experienced User
when many say they tried a reset, they end up just rebooting it.
Did you do a full reset of the system and reinstal? Meaning setting it back to factroy?
You can push and hold the reset button for 7-15 seconds while powered on to achieve this.
Then you'd need to fully reinstall it.
do you have a screen snip of the cable connections page and the logs? that helps as well to check the connections.
