Dannymkelly's avatar
Dannymkelly
AC1600, C6300 CM MAC is MAC-2, xfinity want's MAC-2 not MAC for installation
Just trying to get out the simple information that the CM MAC, I do not know what it is, is not the same as MAC that you acquire from the modem, arp -a, label, etc.  The CM MAC = MAC-2.  So if you give xfinity the MAC, they will not install your modem.  They want the CM MAC that is not always available.
Spent hours with Netgear and xfinity trying to get my modems/routers to work.  No luck.  They do not know what CM MAC is and all a person can find out is the MAC.  So if you cannot install your modem, try MAC-2.  Do not know why this is a secret.  Why xfinity and netgear support do not know this fact.  I had no problems installing the modems using MAC-2.  Only takes a couple of minutes with xfinity app.
1 Reply
