Karhae
Jun 21, 2017Follower
AC1600 D6300 Modem Router
I bought this router/mdem-AC1600-for my small house. It's supposed to run up to 680Mbps but I know it's not running that. I am not technically savvy, so all the firmware talk and software, etc is ov...
DarrenM
Jun 23, 2017Sr. NETGEAR Moderator
Hello Karhae
In the wireless settings of the modem there is a setting wireless channel you may want to change this channel until you find one that gives better signal. If you have a android phone Netgear has a app called Netgear wifi analytics that can tell you the best channel to use.
DarrenM
