SteveDavisPsyD
Jul 30, 2019Guide
AC1600 Modem/Router (Model No. C6250) Problems with WIFI
Within the last several months, I have noticed that when in my office (where I have the AC1600 [Model No. C6250] modem/router) I have had difficulty maintaining connections with my iPhone, iPad, and ...
- Jul 31, 2019
Maybe a minute or less.
Jul 30, 2019Guru - Experienced User
Has a factory reset and setup from scratch been performed?
Is IPv6 enabled on the modem?
What iOS versions are installed on your apple devices?
SteveDavisPsyD
Jul 30, 2019Guide
I just discovered the channel setting and reset the channel. The 2.4 G was set to Auto. I moved that to channel 1. The 5G was set to channel 153. I moved it to channel 36.
