SteveDavisPsyD
Jul 30, 2019Guide
AC1600 Modem/Router (Model No. C6250) Problems with WIFI
Within the last several months, I have noticed that when in my office (where I have the AC1600 [Model No. C6250] modem/router) I have had difficulty maintaining connections with my iPhone, iPad, and ...
- Jul 31, 2019
Maybe a minute or less.
SteveDavisPsyD
Jul 31, 2019Guide
How long does the factory reset take?
Jul 31, 2019Guru - Experienced User
- SteveDavisPsyDJul 31, 2019Guide
So, I just performed the factory reset. Now I can't log into my router. When it asks me for the serial number (and I enter the correct number from the bottom of the modem/router), it tells me that the serial number is incorrect.
I figured it out. Since I did the factory reset, my laptop had logged into another router in the house 🤦🏼♂️. Once I figured that out, everything is done and seems to be working better.
- FURRYe38Jul 31, 2019Guru - Experienced User
Glad you got it working.
Enjoy. :smileywink:
