password123
Aug 05, 2022Aspirant
AC1600 WiFi Cable Modem Router (C6250) Firmware Update
Does anyone know how to manually run a firmware update for this product?
password123
Aug 06, 2022Aspirant
I'm supposed to have speeds around 100 mbps and it's consistently around 20-30 mbps.
Aug 06, 2022Guru - Experienced User
are you testing hardwired?
Over wireless? And if wireless, what band are you testing on?
Do you have a screen snip of the cable connections page (shows the upstream/downstream info) and the event logs?
