password123
Aug 05, 2022Aspirant
AC1600 WiFi Cable Modem Router (C6250) Firmware Update
Does anyone know how to manually run a firmware update for this product?
kmaltshop
Dec 23, 2022Aspirant
My ISP says since I bought my own router and did not rent from them that to update my firmware I will need to contact "the manufacturer"....Netgear. :>) Does anyone have the download or what is needed to update the firmware? I don't think I'm going to get anywhere with Mediacom (ISP). Current FW version is V1.01.13. Thank you much!
- plemansDec 26, 2022Guru - Experienced User
There is NO WAY for an end user to update combo devices. Its built into the provisioning that the ISP sends to the device.
so maybe that screen snip of the cable connections page and event log can help with figuring out the stability issues.
