Cybexus
Jan 06, 2023Follower
AC1750 - Will a factory reset clear the event logs?
Simple question: Will performing a factory reset on an AC1750 automatically clear all the data, specifically the event logs? I'm giving my router away and want to make sure it's clean of any sensitive...
Jan 06, 2023Guru - Experienced User
10 second press then release of the reset button is all that's needed.
