oldman2's avatar
oldman2
AC1750 C6300 Access Control List
I have disabled all wifi security and connected by wifi an internet radio thru the AC1750 C6300 in Gateway mode. The radio is playing and all is well but it does not show up in the Attached Devices list. Where should I be looking?  TNX
  • This can be be marked as closed.  I was expecting the  AC1750 C6300 Access Control List to work the same as it does in the Netgear WNDR3400 that I am replacing, silly me.  I guess that having used it for years the WNDR3400 seems much simpler and more intuitive.
    TX
  • plemans's avatar
    What do you mean by gateway mode?
    Your description doesn't make a whole lot of sense. You've disabled your wifi security but have the C6300 in gateway mode?
    The C6300 has either modem/router mode or modem only mode.
    What exactly have you setup on your C6300?
    • FURRYe38's avatar
      Gatway mode means Router mode is enabled along with the modem.
      • plemans's avatar
        I get it. Was just confused because it was being pointed out.
