abigailhe
Dec 22, 2020Tutor
AC1750 C6300 Blinking upload light & no download+internet light Optimum
I bought this modem/router on June and has been using Optimum serivce with it. Everything worked perfact at first but I've been noticing the upload, download and internet lights were either blinking ...
- Dec 23, 2020
Factory reset it. disconnect coax, then while powered on, push and hold reset for 7-15 seconds.
Once done, reconnect coax, reboot it, then try reinstalling it.
If it reinstalls and works, recheck that cable connections page.
if its still showing offline, your isp needs to check the lines. you have t3/t4 errors/timeouts. usually means its not getting a signal.
Dec 23, 2020Guru - Experienced User
Technicians are always blaming modems. its their go to response "its not optimum equipment so we don't do anything" basically.
If you have any splitters, amplifiers, or signal attenuators attached to your coax line remove them. direct connect the coax from where it comes into your home to the modem. Make sure its not split or anything else. this ensures that nothing in your home is the issue.
then connect to it and see if it works. If it does, log in and get a screen snip of the cable connections page and the logs.
That helps as actually look at the signal. (which the tech isn't going to do being 3rd party).
- abigailheDec 23, 2020Tutor
plemans Thank you for the suggestions! There is no spliiter, amplifier, or signal attenuator on my coax cable. Only comes with the male F-Type connector (I believe this is the cable I have). The coax cable is from the rooftop, bc I live in the top fl and I'm the only person using the line.
I unplugged the coax cable and saw the upload light remain blinking while the download & internet lights still off. Then I plugged the coax cable back and nothing had changed...
- plemansDec 23, 2020Guru - Experienced User
with it hooked up, log into the device and get a screen snip of the cable connections page and the event logs. That helps us check the connection.
Post them back here. click on "choose file" and add that route. it only lets you do 1 at a time but lets us view them right away.
