abigailhe
Dec 22, 2020Tutor
AC1750 C6300 Blinking upload light & no download+internet light Optimum
I bought this modem/router on June and has been using Optimum serivce with it. Everything worked perfact at first but I've been noticing the upload, download and internet lights were either blinking ...
- Dec 23, 2020
Factory reset it. disconnect coax, then while powered on, push and hold reset for 7-15 seconds.
Once done, reconnect coax, reboot it, then try reinstalling it.
If it reinstalls and works, recheck that cable connections page.
if its still showing offline, your isp needs to check the lines. you have t3/t4 errors/timeouts. usually means its not getting a signal.
abigailhe
Dec 23, 2020Tutor
Screenshot 2 of event log
Dec 23, 2020Guru - Experienced User
- abigailheDec 23, 2020Tutor
Thank you plemans .
Did the factory reset and reinstallation. The reinstallation worked and when I checked back the "cable connection" on the page, it shows "failed"...(including a screenshot here).
Optimum checked this morning and I was told once agian that everything looked fine on their end. But thanks for the info. At least now I know my modem is actting properly.
- plemansDec 23, 2020Guru - Experienced User
I have no idea how they checked. Its usually by pinging/connecting to the modem. but if its offline, there's no way to "check it" remotely.
Got it. Thank you. Yeah they only checked it remotly on their system but I also schduled an appintment to have their technician come in and check next wk. Hopefully the technician will do his job...
