abigailhe
Dec 23, 2020Tutor
AC1750 C6300 Blinking upload light & no download+internet light Optimum
I bought this modem/router on June and has been using Optimum serivce with it. Everything worked perfact at first but I've been noticing the upload, download and internet lights were either blinking ...
- Dec 23, 2020
Factory reset it. disconnect coax, then while powered on, push and hold reset for 7-15 seconds.
Once done, reconnect coax, reboot it, then try reinstalling it.
If it reinstalls and works, recheck that cable connections page.
if its still showing offline, your isp needs to check the lines. you have t3/t4 errors/timeouts. usually means its not getting a signal.
abigailhe
Dec 23, 2020Tutor
Got it. Thank you. Yeah they only checked it remotly on their system but I also schduled an appintment to have their technician come in and check next wk. Hopefully the technician will do his job...
abigailhe
Dec 29, 2020Tutor
Updating my situation. Finally the Optimum technician came and the coax cable didn't have signal. It turned out the coax cable from the backyard was disconnected. Once he reconnected it, the internet worked probably (at least for now). Altho it makes me think I should swtich to Verizon for a more stable internet...
