oldman2
Jan 20, 2020Aspirant
AC1750 C6300 bridge mode
Hello, How can I access the control panel of an AC1750 C6300 when it is in bridge mode from a browser thru a router N600? http://192.168.0.1 doesn't fail but doesn't bring up the screen and http://...
antinode
Jan 20, 2020Guru
> [...] I am replacing an N300 C3000 which did this using 192.168.100.1.
Did you try "192.168.100.1" (possibly after disconnecting the router,
and connecting a computer directly to the C3000)?
> [...] a router N600 [...]
"N600" is a speed, not a model number. Look at the product label.
- oldman2Jan 20, 2020Aspirant
Sorry, try WNDR3400 as the model number.
Anyway, I am trying to transfer all the router setup from the WNDR3400 to the AC1750 C6300. Access list is stumping me, I'm used to be able to transfer devices from the Attached Devices list to the Access Control list by clicking. TNX
How can I attach a screen capture here?
- FURRYe38Jan 20, 2020Guru - Experienced User
You'll need to manually input any configurations into the router your going to use as your router.
Are you using the C6300 as your main host router?
oldman2 wrote:Sorry, try WNDR3400 as the model number.
