oldman2
Jan 20, 2020Aspirant
AC1750 C6300 bridge mode
Hello, How can I access the control panel of an AC1750 C6300 when it is in bridge mode from a browser thru a router N600? http://192.168.0.1 doesn't fail but doesn't bring up the screen and http://...
oldman2
Jan 21, 2020Aspirant
I need to re-state my problem more precisely. I have the AC1750 C6300 in Bridge mode, how do I get it back into the default Gateway mode given that ip 192.168.0.1 does not connect?
TNX
- antinodeJan 21, 2020Guru
> [...] how do I get it back into the default Gateway mode given that ip
> 192.168.0.1 does not connect?Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "reset".
> Did you try "192.168.100.1" (possibly after disconnecting the router,
> and connecting a computer directly to the C3000)?Still wondering.
- oldman2Jan 21, 2020Aspirant
Thanks for responding, I have connected the AC1750 C6300 (while in bridge mode) directly to the computer. It does not respond to either 192.168.0.1 or 192.168.100.1; I'm hoping somebody knows the correct address. I hate to think I must use the previous suggestion from another user.
Reset, yes, I have downloaded the user manual and I know how to do (and have done) a full reset and it does work. Unfortunately all the configuration work I have done gets blown away also. Its a very painful way to just change the mode. And no, I can't get back into the AC1750 C6300 to back up the configuration before doing the reset. Sorry, not wanting to be a jerk but this is frustrating.
TNX
> [...] I have connected the AC1750 C6300 (while in bridge mode)
> directly to the computer.And how was the computer configured when you did that?
> [...] It does not respond to either 192.168.0.1 or 192.168.100.1;
> [...]What _does_ happen? Actual error message(s)?
> [...] I'm hoping somebody knows the correct address.
I don't know what (if any) IP address the C6300 might use in
modem-only ("bridge") mode. The "192.168.100.1" address is a special
case, used to access a DOCSIS modem. But, if the computer itself is
misconfigured (because there's no available DHCP server, for example),
then I wouldn't bet on it working.
> [...] I can't get back into the AC1750 C6300 to back up the
> configuration before doing the reset. [...]As you've probably realized by now, the time to save the old/good
settings is _before_ you make the crippling mode change.As a last (or first?) resort, I'd try connecting the
C6300-as-modem-only to the WNDR3400-as-router, and the computer to the
WNDR3400. Assuming that the computer can access the management web site
of the WNDR3400 at its default LAN IP address ("192.168.0.1"), then I'd
try "192.168.100.1" to get to the C6300-as-modem-only.
