ASW21
May 07, 2020Tutor
AC1750 C6300 Internet Connection randomly drops
Our AC1750 C6300 cable model router has been randomly dropping the internet. No changes have occurred (other than going from 2 to 4 users), have turned it off to recylce several times which hasn't he...
- May 15, 2020
ISP fixed the issue and prblem solved. Thank you!
May 07, 2020Guru - Experienced User
log into the C6300 and get a screen snip of the cable connection page that shows the connection back to the isp .also get your logs. between these 2, we can look at the connection back ot the isp.
Also, if you have any splitters, attenuators, or amplifiers in the coax line, remove them.
check the connections for being loose, corroded, damaged, kinked, or any other issue with the coax.
- ASW21May 07, 2020Tutor
i'm a bit of a novice - can you give me directions how to grab the info you requested?
