ASW21
May 07, 2020Tutor
AC1750 C6300 Internet Connection randomly drops
Our AC1750 C6300 cable model router has been randomly dropping the internet. No changes have occurred (other than going from 2 to 4 users), have turned it off to recylce several times which hasn't he...
- May 15, 2020
ISP fixed the issue and prblem solved. Thank you!
ASW21
May 07, 2020Tutor
i'm a bit of a novice - can you give me directions how to grab the info you requested?
May 07, 2020Guru - Experienced User
when you first log into the C6300 through the browser. Click on the cable connection icon. That'll take you to the cable connection page.
Logs are found at: advanced----administration---logs
- ASW21May 07, 2020Tutor
- plemansMay 08, 2020Guru - Experienced User
It is. You'r downstreams boarderline. its still within range and doesn't have any errors.
Opposite is true of your upsteam. You're power levels are way to high and can be whats causing the issue. Plus you only have 1 locked upstream channel. With that high of a power level and only 1 locked channel, any slight issue will cause drops.
If you don't have any amplifiers, signal attenuators, or splitters in line and the modem is connected right where to coax enters the home, I'd have the ISP check the line.
- ASW21May 08, 2020Tutor
Thank you so much. ISP confirmed your findings and it is being addressed.
