Brogama
Mar 22, 2020Aspirant
AC1750 C6300 Internet Drops
Most recently I have noticed progressively more restarts of the modem is needed to resolve dropped internet. One instance there was an amber upstream LED. I logged on and noticed a lot of correctables...
- Mar 22, 2020
Try this. move the modem to directly where the coax enters the home. remove any splitters, attenuators, amplifiers and directly connect the modem there.
then use the combo device and see if you have the drops/issues.
your power levels on your upstream are boarderline. And power levels can fluctuate throughout the day. potentially you're dropping below upstream threshold and that's whats causing the issue but its tough to tell as its just shows from when you took the screen snip.
Mar 22, 2020Guru - Experienced User
- BrogamaMar 23, 2020Aspirant
I was able to move the unit closer to the main supply and my performance has improved!! I am looking to update the line to make a direct line from the side of the house to where the router is located and reduce all unions.
- FURRYe38Mar 23, 2020Guru - Experienced User
Sounds like a good direction your going in.
