Brogama's avatar
Brogama
AC1750 C6300 Internet Drops
Most recently I have noticed progressively more restarts of the modem is needed to resolve dropped internet. One instance there was an amber upstream LED. I logged on and noticed a lot of correctables...
  • plemans's avatar
    Mar 22, 2020
    Try this. move the modem to directly where the coax enters the home. remove any splitters, attenuators, amplifiers and directly connect the modem there.
    then use the combo device and see if you have the drops/issues.
    your power levels on your upstream are boarderline. And power levels can fluctuate throughout the day. potentially you're dropping below upstream threshold and that's whats causing the issue but its tough to tell as its just shows from when you took the screen snip.
