PeterJames
Feb 10, 2022Follower
AC1750 C6300V2 HAS SOLID AMBER UPSTREAM LED. ALL OTHERS GREEN.
New Nighthawk AC1750 C6300V2 HAS SOLID AMBER UPSTREAM LED. ALL OTHER LEDS ARE GREEN AND THE MODEM/ROUTER SEEMS TO FUNCTION WELL. WE'RE CONNECTED TO A RESORT CABLE SYSTEM MANAGED BY DISH. WHY IS THE U...
michaelkenward
Feb 11, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge. Your problem seems to be to do with the modem bit.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
PS No need to SHOUT. It makes messages hard to read.
