PeterJames
Feb 10, 2022Follower
AC1750 C6300V2 HAS SOLID AMBER UPSTREAM LED. ALL OTHERS GREEN.
New Nighthawk AC1750 C6300V2 HAS SOLID AMBER UPSTREAM LED. ALL OTHER LEDS ARE GREEN AND THE MODEM/ROUTER SEEMS TO FUNCTION WELL. WE'RE CONNECTED TO A RESORT CABLE SYSTEM MANAGED BY DISH. WHY IS THE U...
Feb 11, 2022Guru - Experienced User
do you have a screen snip of the cable connections page and the event logs?
that'll help us check the line.
Remove any splitters, signal attenuators, or signal amplifiers from the line.
Check for any kinks, damage, wear, old/bad/cheap connections and replace them if there are.
Preferably move the modem to right where the coax comes into the home to prevent the wiring in the home being the issue.
