Inernot44
Aug 01, 2022Aspirant
AC1750 C6300v2 Modem/Router No internet LED light
I’ve got a AC1750 C6300v2 Modem/Router and the internet LED light isn’t on. Still have internet, but streaming is slow and continually drops. When speaking to Optimum internet provider, they said...
Aug 01, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
- Inernot44Aug 02, 2022Aspirant
- Thank you! Here are the modems connection numbers.
- FURRYe38Aug 02, 2022Guru - Experienced User
The power is a bit too low.
Also have some Correctables but not bad.I would have the ISP check the signal on the line. Review the link posted regarding power levels.
Check the Coax line for fittings and ensure they are snug and no kinks. Remove any coax line splitters.
You ISP needs to look into this.
Post the Events Log page as well.
Thanks for getting back so quickly. Is low power a reason for the internet led to be dark? I’ve spoken to Optimum (ISP) and they are terrible and only recommend me using their routers. Which I despise because of fees but also because they are often outdated.
Here is the Event log as requested:
